RESET SERVICE LIGHT
Отварям нова тема и нека тук само проверени неща да се пишат за да сме полезни на колегите а не да се пита все едно и също!
Ето един линк: <!-- m --><a class="postlink" href="http://www.matthewsvolvosite.com/reset.php">http://www.matthewsvolvosite.com/reset.php</a><!-- m -->
и неговото съдържание:
Reset Volvo 850 XC70 S70 V70 C70 S80 Service Light
By Matt
850 (1993-1995)
There are two diagnostic units(it says A and B on the cover) located adjacent to washer reservoir under the hood.
1. Turn on the ignition and open the module A and insert the flylead into socket 7.
2. Press the button on the diagnostic unit 4 times, briefly but firmly.
Then the LED illuminates and stays illuminated, and the system is ready to accept manual code input. A code number for resetting the service reminder light is 1-5-1.
3. To do this, press the test button once and release it. And LED illuminates again.
4. Then press 5 times and wait for the LED to illuminate.
5. Press the button once and LED should flashes several times in succession and the reminder should have been reset.
6. Switch off the ignition and replace the flylead in its holder and close the cover.
850 (1996-1997) and S70 and V70 (1998)
You need an OBDII tool that resets Volvo service light codes. See this service light reset forum thread for more. They run about $100 to 200 -- or -- take it in to the dealer or independent Volvo mechanic and have them do it. Call to see if they charge for this first. Note: I've read reports of people having success with having the local Shucks/Pep Boys/Checker auto parts store do it.
S70 and V70 and C70 and XC70
1. Press and hold odometer reset button.
2. Turn ignition switch to Run.
3. After SRL flashes, release odometer reset button.
4. Confirm by turning your Volvo off, then on again.
S80
1. Turn ignition switch to position I.
2. Press and hold "day counter reset button".
3. Turn ignition to position II.
4. Continue holding day counter for about 10 seconds.
5. While SRL flashes, release day counter button.
6. Should hear "beep-beep" to confirm command accepted.
S40 and V40 (1999+)
1. Hold down the odometer button
2. Turn the ignition so all the lights come on
3. Keep holding the odometer down for 30 secs or until the service light starts flashing
4. Release the odometer button while service light flashing
5. Turn off and on again to check
VOLVO S60 2001г. D5
VOLVO XC90 D5 ТЪРСИ СЕ!
[Image: a1_a1_28_11_1994_2_1a.gif]
By Matt
850 (1993-1995)
S80
S40 and V40 (1999+)
VOLVO S60 2001г. D5
Ето още по темата:
Линк : <!-- m --><a class="postlink" href="http://www.marshost.com/~rashmun/volvo.reset.htm">http://www.marshost.com/~rashmun/volvo.reset.htm</a><!-- m -->
Съдържание:
XC 70 2001
Steps must be completed within 5 sec. between each step:
-Make sure the trip meter is in T-1
-Turn ignition key to position 1
-Press and hold trip meter button until zero is shown
-While still holding the trip meter, turn key to position 2
-When trip mileage returns, release the trip reset button
Turn key to off
s60 2002- 03
To reset the service reminder indicator:
-Ignition position I
-Press and hold in the reset button for the trip odometer
-Ignition position II.
Note! Turn the key to position II within 2 seconds.
-Hold the reset button for the trip meter pressed in until the original value has been reset.
Note! For the 2003 model year a general yellow lamp will light when the reset button must be released.
-Release the reset button for the trip odometer within 4 seconds. The instrument gives an audible signal when resetting has succeeded
-If the trip meter is already reset the reset button should be held in for a minimum of 10 seconds and a maximum of 14 seconds.
Note! If the reset button for the trip odometer is not released within 4 seconds, the service reminder indicator is not reset.
s60 2001
-The indicator starts flashing when the reset button for the trip odometer has been pressed for 10 seconds
-Release the reset button for the trip odometer within 5 seconds. The instrument gives an audible signal when resetting has succeeded.
Note! If the trip meter reset button is not released within 5 seconds the indicator is not reset. However the indicator will stop flashing.
850, S70
V70, S80 1996-97 1998-00 1999-00
Service reminder lamp must be reset with either a Scan Tool Connected to the Data Link Connector (DLC), or connect a Volvo Rest Tool to the DLC and press the button on the tool to reset.
240 1986-93
When the "SERVICE" is illuminated, reach behind the instrument panel and push the level located between the tachometer and speedometer.
740, 780 1986-88
1988-90
When the "SERVICE" light is illuminated, reach behind the instrument panel and press the button located to the right of the speedometer.
740, 760
850
w/ Yazaki Cluster*
940, 960 1989-92 1986-90 1991-97
When the "SERVICE" light is illuminated, remove the cap on the face of the instrument panel between the clock and the speedometer. Insert a thin-bladed tool into the cavity and press the reset button. *Odometer above the speedometer needle.
All Models 1999
Press and hold trip odometer reset button. Next, turn the ignition key to the run position KPII (not the start position). Wait 30 seconds or until service light begins blinking. Turn the ignition to off position. Release the Trip Odometer button.
850w/ VDO Cluster* All Years
To reset the Service Reminder Indicator, turn the ignition on while the engine is not running. Access the diagnostic unit located on the left fender well under the hood. Connect the single wire plug to terminal #7. Press the reset button four times shortly. When the LED glows, press the button once. When the LED glows steadily again, press the button five times. When the LED glows steadily again, press the button once. After the LED gives a couple of rapid flashes, the system is reset. Unplug the connector and turn the ignition off. *Odometer located below the speedometer needle.
VOLVO S60 2001г. D5
Ето още по темата:
Съдържание:
XC 70 2001
Turn key to off
s60 2002- 03
s60 2001
850, S70
240 1986-93
740, 780 1986-88
1988-90
740, 760
850
w/ Yazaki Cluster*
All Models 1999
Attached Files Thumbnail(s)
VOLVO S60 2001г. D5
И още от Google
Линк:http://www.volvoclub.org.uk/reset.shtml
Съдържание:
Volvo 850-70 Service Light Reset
RESETTING 5000 MILE SERVICE LAMP ON 1994 + 1995 850
NOTE: This function is for the service reminder lamp, be sure you have performed the proper service such as changing the oil before resetting. If the check engine lamp is illuminated when the car is running, you'll need to have the car looked at by the Volvo dealer for proper diagnosis.
1. Turn on the ignition to the KPII position so the warning lamps on the dash are illuminated. Do not start the car.
2. Open the bonnet of the car and locate Diagnostic test port (A) behind the driver side headlamp.
3. Remove the cover and pull the jumper wire out of the holder in the cover.
4. Insert the jumper into terminal #7, then press button 4 times, wait approximately 5 seconds and the red lamp should glow continuously. You are now in the data reset mode.
5. Press the button 1 time and wait approximately 5 seconds for the lamp to glow again then press the button 5 times. After about 5 seconds the lamp will illuminate again, press the button 1 time and you will see the lamp flash repeatedly for a couple of seconds indicating that the service lamp has been properly reset.
6. If a mistake is made, simply switch the ignition off and back on to reset and start over.
1996 Model (Some of them)
On these models the diagnostic socket is in front of the gear stick. Switch the ignition on. As you look at the speedometer on the dash, beneath it opposite the trip reset button is a rubber plug. Remove the plug and with a thin pointer such as a ball point pen, depress the pin. This will reset the service light.
1999 Model Service Lamp Reset Procedure
1. Press and hold trip odometer reset button
2. Turn ignition key to run position KPII (not the start position)
3. Wait 30 seconds or until service light begins blinking
4. Release Trip Odometer button
5. Turn ignition to off position
VOLVO S60 2001г. D5
И още от Google
Съдържание:
VOLVO S60 2001г. D5
И последно от мен за колегите с С60 Smile
Here it is for all you guys who are proud Volvo owners s60 years 01-03 maybe newer cars too.
Resetting the Service reminder indicator (SRI), model years -2001
The service reminder indicator (SRI) informs the driver that it is time for the car to be serviced. The lamp remains lit for 120 seconds when the ignition is switched on.
Note! If the lamp flashes, it may be because one of the service parameters has not been programmed.
Proceed as follows to reset the service reminder indicator (SRI):
-The service reminder indicator (SRI) starts flashing when the reset button for the trip odometer has been pressed for 10 seconds
Resetting the service reminder indicator (SRI), model years 2002-
The service reminder indicator (SRI) informs the driver that it is time for the car to be serviced. The text message is displayed for 120 s each time the ignition is switched on.
Note! For all vehicles from the 2003 model year a general yellow lamp will light when the reset button must be released.
Note! If the reset button for the trip odometer is not released within 4 seconds, the service reminder indicator (SRI) is not reset.
VOLVO S60 2001г. D5
VOLVO S60 2001г. D5
Темата е полезна и ще я направя важна, поне ще спестим на много бъдещи колеги писането по този изтъркан вече проблем.
Volvo 360GLE лети с попътен вятър :-), а да и едно S70 2.5 TDI не него не му требе попътен ветър Big Grin
2 Guest(s)
